dolt
Well-Known Member
You will find that most cam manufacturers always understate compression rating for their cams; CYA stuff. You will have to trust me on this in spite of what Andrews or other cam manufacturers advertise. You will notice some improvement if you install the 57 cams but it takes static CR of 10.2 to bring those cams to life. If you take the time to go on line and use the BigBoyz compression calculator to compare cams, you will see for yourself which cams would be best suited for you application. Personally, I say stick with the SE255s with an otherwise stock or Stage I configuration.
A good target for a street build would be to set CCP between 190-195psi and/or corrected compression between 9.3 and 9.5. If you set up the calculator at 9.6 static, you will se that the 57 cams produce corrected compression at 8.97 and CCP at 184.5psi compared to the SE255 which produce corrected CR at 9.36 and CCP at 194.7psi; perfect for a street build. The Andrews 48 numbers are 9.26 and 192psi; all numbers are at sea level so would have to be adjusted for your altitude but you get the picture.
Of the Woods cams, the 222 is the only one worth a look but it isn't much better than the 57 at 9.1 and 188psi.
http://www.bigboyzheadporting.com/TwinCamComp.htm
Just providing some real world data for your consideration; your ride, you decide.
