dolt
Well-Known Member
I think the $200 is for the license unless you are buying the PV; there is no "flash". If you are buying the PV, you have the license by default and he should be charging $300 for the tune as he is not selling you a license. A cam change is about a 4 hour job and, depending on location, shop rate will run at least $75/hour and most will be $90 to $100, so $400 for the cam install is reasonable.
