How can it gravity feed when the oil tank is lower than the pump?You can take the Ball check valve out. That's the round screw in cap closest to the engine. This usually allows the pump to prefill with oil. It should flow out the hole. It should also flow out the tappet screen hole. It takes a while to gravity feed & prefill this way. Once oil is coming out of one hole, plug it and wait on the other. Then plug it. This fills the pump and removes any air for cavitation. Retry after that for the 20 sec. running. I usually watch the light and watch for circulation in the oil tank at the same time. Keep us posted.
tourbox
Very good point. I was thinking of Soft Tails. In that case, remove the 2 screw caps I mentioned. Remove your oil supply line to the pump and plug it off with a bolt and hose clamp. Then take old style oil squirt can and start squirting oil into the feed hole/fitting of the Pump, pretty messy, until you see the oil coming out of the 2 unplugged screw caps. 2nd. option is to hook up plastic bottle to the oil pump nipple by way of a 3/8(?) hose. I use to use a gear oil bottle because it had a tapered end on it for the hose to slide over. Make sure the bottle is CLEAN before putting oil in it Raise the bottle and let gravity do it's thing. Keep us posted.
tourbox
I'm removing the oil pump again. Does anyone know of a good tool or trick to remove that tiny retaining ring on the pump shaft?
