For RibEye--No not a stupid question. To do that you would have to disconnect them from the oil tank under the tranny. But they may be different lengths or preformed shapes.
Mel Neff;As for alignment the way I do it is as follows; remove both the pinion gear and the oil pump drive gear off of the pinion shaft so they are not in contact with the drive gear of the pump. You can not turn the pump shaft with those in place. Assemble the pump completely and torque to specs. I reach in, the nose cone, and turn the pump gear by hand SLOWLY and check for any binding. I will rotate the pump 4-5 revolutions in each direction. You may feel a little resistance from the pre-lube(oil) of the pump. This will be an even resistance. If it is binding you will notice it only 1 or 2 places of the rotations. If you feel the binding or rough spot then loosen the 6 allens and shift the pump body a little one way or the other. Re torque the pump and check again. Keep doing this until you have no binding. I've had to do this 5-6 times on some bikes, sometimes I'm lucky and get it the 1st. try. Once it is free,no binding,then reassemble your nose cone.
The reason this is done is because if there is binding it can shear 1 of the 3 wood drift keys or all 3. It may happen at start up or miles down the road. Depends on how much they were in a bind.
With the gauge and no oil in the line I would assume the switch good also.
Oil is pumped thru the lifters up thru the push rods to lube the rocker arms and valve springs etc.
tourbox
