I removed the nose cone again, checked the gears and keys, realigned the pump, blew out oil passages. I am now CERTAIN that the pump is turning. Back together, still NO oil pressure.
Maybe it's time to bite the bullet and take it to the Harley shop.
Did you pack the pump cavity with vasoline? Pretty sure someone else already mentioned that, but I don't remember your reply to that specific question.
You may of tried this already. The feed line comes from the bottom of the oil tank(pan) on the primary side about mid way of the oil pan according to the parts diagram. Is that correct? Have you disconnected that line, at the pump, push it lower than the pan and seen oil coming out of it? It should flow pretty good.
Yes, I've done that. Doesn't gush out, but is a steady stream.
I couldn't tell from the parts book where the return line went to the oil pan. I know it comes from the oil filter though. Just didn't see any thing labeled oil return in parts manual. It should be higher than the feed line and maybe on the clutch cable side, just don't know.
tourbox
Does packing it with vasoline work better than filling it with oil thru the top cap?
As Jennmarr suggested you might try 10-15 lbs. of air pressure in the tank to pre fill the pump. Remove your ball check valve and watch for oil to come out with the air pressure.
This is really confusing to me. Never had anywhere near this much trouble priming a pump.
tourbox
