danthern
Question/suggestion. Would removing the air filter and placing a finger tip over each vent tube while the engine is idling alter the flow momentarily enough to check the vent system as a noise source? How close to the cam cover is the exhaust pipe and heat shield, close enough to interfere with engine shake?
I have the K&N high flow filter so those stock vent tubes aren't present. As to the exhaust, I've ran the engine without exhaust and the noise is present. Thanks for the thought!
