BUBBIE
Well-Known Member
I'm beginning to think that's the thing to do...no tunes but earplugs make it tolerable. I could make the pipes louder....just hate to settle....
NOW I'd Not suggest this to anyone else...
You said when the top valve cover is OFF the Noise is gone?
Why not try to Drill a hole thru the cover (area hidden on top) and place some type vent that you can attach a small hose to it and just let it Vent UP there.
OR ? A hole big enough that will fit a small tubeless valve stem and just allow it to be OPEN.? This valve stem would seal off the hole and allow air in and out....
IF it Whistles Maybe it will play a tune:swoon
Not too UNpractical and might work... OR a 90* elbow and tube running Down and allow any oil mist to drain out below the engine.
I AM As stumped as you are...
IF the cover is off and no noise WHY would this not work? It has to be something to do with the top cover and you have tried two gaskets and nothing worked there.... Now my thinking is it has to be air...:eam
