flh canuck
Well, got my engine back together yesterday after installing the new Stage 2 103" kit with the SE255 cams.
My engine mods now consist of:
SE air intake
SE Fatshotz mufflers with 8 discs and open end cap on each side
SE Stage 2 big bore kit (103" and flat top pistons)
SE 255 cams
SE inner cam bearings (timken)
Fired her up, runs real nice, valve train nice and quiet, good oil pressure and no leaks... very happy.
Down loaded the applicable Stage 2 map on my SEPST (205UH005) and went for a quick ride.
Noticed the exhaust note sounds a little more aggressive and wow does this engine ever pull nicely from 2500 rpm on. I've read posts that say this cam falls off at around 4500 rpm but my engine happily spins right past the 5 grand mark with no signs of slowing down. By that time, I am well into losing my licence territory so am pretty happy with the performance.
Only issue thus far as the engine is generating a lot more heat than before and there is a slight stumble/ hesitation off idle and some decel popping when slowing down btwn about 2500 and 1500 rpm.
The heat is no doubt due to the larger bore/higher compression as well as brand new components breaking in but I also get the sense that the engine is running lean in the lower rpms. Only got to ride for about 10 15 minutes and when I came back to the shop to check for leaks, the heavens opened up and of course the rain hasn't stopped since (love the west coast...).
I checked the new map specs and noticed it is set up to run closed loop from 750 to 4000 rpm. I noticed from reading previous posts here that you gents discussed increasing your ve tables 5-10 percent across the board.
Not sure if I should do that first and then run smart tune or if I should just run a smart tune session with basic map as is just to see where I am at and how far off the original tune is.
In any case, I am looking forward to finally playing with the smart tune to see how much things improve. The previous canned map I used for the Stage 1 worked perfect out of the box but this one is going to need a little work.
At the end of the day, I may take it out to Jarz Performance and have them run it on the dyno to make sure a/f is where is should be but I would like to get it as close as I can first. The adventure continues...
Any suggestions or advice is always appreciated.
Another quick update on my SEPST adventure.
Was playing with the smart tune function and recorded a base run in the shop just to see if I could get an idea of where things were at with the canned map. Of course only running at idle and up to 2000 rpm in neutral. Didn't want to run for too long either cause don't want to overheat things.
Allowed the smart tune to do its thing and it came back with several cells at the low end of the scale filled in. The suggested settings for the smart tune modified cells in the VE chart were as much as 10 points higher than the current map.
Kinda confirmed my thoughts that things were a bit lean.
I decided to err on the side of caution and increased all the values for the front and rear VE charts by 7.5%.
Re-flashed the ECM and noticed an immediate difference. Idle is a bit smoother and more importantly, no more stumble or hesitation when whacking the throttle open. Throttle response is now as good as it was before all the engine mods.
Made another short recording and smart tune is suggesting going with slightly lower VE values now in a few cells (off by two points). I am good with that as I would rather be a little on the rich side for now.
Very impressed with this Super Tuner (now that I have figured out how to read the charts and actually make changes....)
Looking forward to getting on the road and running some proper recordings during actual driving conditions.
SE air intake
SE 255 cams
