If it spins the engine over with the plugs out the pistons are not seized You sure about NO breakers, Pull the starter off and have it bench tested,
I will take it off and check the starter is there a certain way to do that? once i remove it i ground the frame and apply power , i know it will spin because it spins with the plug wires grounded so is there a kind of voltage/amp check i need to do ??
