Been installing a new Ultima Bullet style sliders and fork tubes in place of the OEM air shocks. Hard part was trying to remove all the original front end equipment without taking the entire inner fairing apart and out. The front sliders by Ultima were listed for a softail. I figured they should fit. Even though the trike is a touring model to begin with. They are now mounted in the Easy Steer triple trees. When I ordered the new front end. I asked for 2" over stock on the length of the fork tubes. Looks like the stock length tubes of a softail are longer than what I originally had on there, besides the extra 2" over. I wont know the looks of the final stance till I have it together and with the weight of the trike resting on the front end. But I did want to go for the ol school chopper look and so far it looks like I got that. I'll do pictures today and will post them soon. I also noticed that the front fender mounts are higher in relation to where they were on the stock front end. Looks like I'll be making special fender brackets to mount the stock front fender in it's respectable position.
When ever I do any build, custom or a stock add-on. I try and make sure I cover every aspect. Though this time, with this new length. It won't be till later today that I'll know if my brake lines and front axle speedometer cable is long enough for my custom application.
zoood
Update: I had to order new extended lower front brake lines and a speedo cable. Also,... the front fender will not mount to the mounts on the sliders. I plan on removing the fender's mounting brackets. I'll be taking them to a custom hot rod shop I know of and have them duplicate the brackets out of 1/4" plate aluminum. The new brackets will be flat, not contoured and shaped like the OEM fender brackets.
zoood
