Im presently building my own full chin spoiler. Of the two types I found out there. One would mount to the inside of the frame's down tubes. This spoiler was made entirely of sheet metal. Where as the other type was made with fiber-glass. This full chin spoiler would not allow installation along with my hard lowers.
Since I'm a stickler for having things my way. I decided to build my own version and update as I build it.
In the picture below,... You'll notice I have the Ultra Cool fan assisted Oil Cooler installed. I had removed the cover that comes with it. Their cover will suffice for their product. I on the other hand like the looks of things to flow together. So I removed the Ultra Cool stock cover for my build.
The easiest material I've found to work with for building a template is card-board. That along with duct tape. Will allow you to form the necessary shape or patterns required.
What you see setting on the trike in card-board is incomplete. I didn't add the surface with the required curvature. There was no need to. My next step in this build, with pictures. Will be the metal bending and forming of the chin spoiler.
The bottom scoop of the spoiler is wider than the back of the front fender. I like this better as compared to the type chin spoiler that mounts inside the frame tubes. This allows for more collection of air flow through the cooler and at the engine.
For mounting the spoiler in it's respectful position. I found that the upper section will insert behind the crash bar or engine guard and the frame. That in it's self seems to hold it nicely. I plan on giving it a rubber "U" channel edge to eliminate any metal to metal sounds.
In the next picture. You'll see that I chose to use the mounting bolts of the engine guard where it mounts to the lower part of the frame. The spoiler's sides actually lay flush against the hard lowers and I will address these areas by bonding a sheet of rubber to the spoilers surfaces. This will make for a tighter looking fit and eliminate any ware to the surfaces from vibration.
To be continued,...
zoood/RJ
To be continued,...
zoood/RJ
