I have mounted a Kuryakyn Hyper Charger to the Ultima 113. I dont like the fact that the engine ventilates into the air cleaner. I had also installed a tubing that was designed with banjo ends on it and an outlet nipple allowing you to hook up a rubber hose and  aim that down at the ground. On my two wheeler this worked. However,... on my trike. The movement of air under the trike was different and when there was any oil mist exiting that line while I was riding. Everything underneath received a thin coating of oil. Nothing major. But I don't want any on my brake disc!
This picture shows the breather tube mounted to the heads.
On the left or rear head. Where the brass nut is. That's where the rubber hose would hook up. I took a different route and picked up a SS braided hose. One that hooks up as a hot water line.( Like in your Bathroom) I added that brass nut showing in the picture. It allows me to attach the line by screwing it on.
Tomorrow I have to purchase a new line. It will hook up in the same place as the one shown but will curve down or swoop back so that in runs along the top of the transmission cover. Thats where it will find a "T" connection. The leg of the "T" will be sticking up and I'll attach this miniature air filter.
Any oil will be returned to the oil filler tube.
I mounted a brass elbow into the rear of the filler tube housing.
I'll end up using black wrinkle paint to cover the brass look.
Tomorrow I'll pick up the rest of my supplies and will finish this out and post pictures.
zoood
zoood
