free website stats program Here's my Trike build | Page 25 | Harley Davidson Forums
Rats Hole got up with me a few moments ago. I'll be in the show on the 12th.
And the winner is ZOOOD Hope to meet up with you in Daytona, Good Luck but you really wont need it, your build is a stand alone IMO:s
jack I managed to get a hold of the 165/65/14 tires. What a difference. They fit very nicely. 3/4" clearance between tire and inner well. Fender skirts also have a 1/2" clearance from the tire as well. thanks for your help.
RJ
RJ
Glad to help, hoping to see you win big in Daytona:s
Finally I found the correct tires for my wheels on the trike's trailer. I also added the fender skirts to match the fender skirts on the trike.
There were a couple of touches I needed to do to my seat. I added a foil they use on ac and heat ducting. This will also aid as a barrier from the engine heat.
On the seat's surface. One of the sunken buttons, the cap of the button popped off and was lost. So I decided to replace the buttons with a Jeweled ruby red facet faced stud. This matches and the jeweled studding on the heat deflector. I added two extra studs up towards the tank. Reason being. I dropped my cigar and melted an impression in the seat! I had no choice but to cover it.
I had finished carpeting the trike's cargo deck. This makes it so easy to keep the small things together and the entire deck can be easily lifted out and set on the passenger's seat allowing access into the cargo area.
zoood
Finally! The trike is all black. Man I hate body work and paint prep and painting! My shop is dusty and needless to add, there's dust in the painted surface. So when the paints all dry by tomorrow. Ill be wet sanding it all with 2000 grit wet/dry sand paper. Then I have to hand buff it out to a glass shine. I dont trust my self using a buffer. Too easy to burn the paint on an edge if not careful. The best compound I ever used and will be using is that Novis #2 Plexi glass polish that's sold at dealerships. Ive been non-stop at finishing the trike,... 7 days a week since capital Jack called me out on doing the Daytona Event. And oh by the way. Hoople,... I'll be expecting lunch. lol
