I started making fender skirts for the trailer and the trike. Turns out the right side wheel opening on the trike is not the perfect mirror image as the left side wheel opening. This holds true for the trailer as well. To be sure I had to make an individual skirt for each wheel opening. ( I couldnt do all four and then drill through them at the same time. I had to make sure each one was fitted to the raised lip they mount against. )
All the holes for the studs holding the skirt on. Were tapped @ 8/32nd's and screws where threaded from the inside, mounted with rubber bonded washers. Which keeps the fiber-glass from cracking around the screw when tightened.
The aluminum "U" channel is to steady the fender skirt when riding or cleaning.
zoood
zoood
