free website stats program Here's my Trike build | Page 22 | Harley Davidson Forums
You should be OK, we are using Deka now @ Sears and having very good results, they are a better battery than Johnson Controls was producing and American made, Good Luck on your on going project always a good read hope to see you in Daytona, Capital Jack:s
I know that Deka is good quality. I used to work at their plant years back in Lyons Station, Pa. I'll let you know for sure if Daytona or Thunder at the beach rally comes into play. We may ride to either or both. June we're riding to Louisiana and 2 weeks later to the Smokies for a trike meet over there and in July/August. Looks to be Kansas as well.
Good Deal, give me a Holler look forward to meeting you:s
Quote : Presently I'm waiting for a friend to get back to me with a schematic that I drew up, but he's proofing it for me. It will allow me to have an aux. battery in the Trike's trailer. When I have that I'll resume that phase of the build.
After much consideration. I decided not to install an auxiliary battery in the trailer. Instead,... I placed it in parallel with the trike's battery and it is now mounted in the trike as well. This definitely helps the trike's battery out. With the new LED tail lights (trike and trailer), Hog Tunes power amp, passing lamps, headlight, antenna amplifier, OEM radio and so forth. I'm sure to have the much needed strength now that the single battery I'm sure was being taxed. With just the one battery and all my accessories on. I could see my voltmeter drop to 11 volts.
zoood
I really wasn't planning on having the aux. battery in the trike. It was planned to go in the trike's trailer. Unfortunately only when the trailer was hooked up to the trike is when I would have two batteries in parallel.
I had welded some 3/4" angle iron together to form a battery box.
Covered two sides with aluminum and carpeted them as well.
The angle iron at it's base allows me to secure it there. Just the removal of those 2 screws and I'll have full access to the aux. battery.
The lid was sprayed with black wrinkle paint and the edges were covered with rubber "U" channel. The lid is removable and held in place with Velcro.
This is the finished auxiliary battery cover installed inside the trike's cargo area.
As for the trike's trailer. I had sprayed black wrinkle finish to the lid's custom opening. Since this RV hatch was designed for a horizontal wall. I had added a 1/8"x1/8" adhesive backed foam rubber seal. This will keep rain out and when I open the trailers lid. Any water trapped on the hatch opening will drain out through weep holes that the hatch already has.
Presently I'm working on the hatch lid. I happened to have some samples of aluminum that has a black vinyl texture pressed into it's surface. This is perfect for the hatch's surface.
On the trailer, I started doing other cosmetics. I placed a LED brake lite on the lid, just as I did on the trike. I get the LED 3rd brake lite set-ups off of a late 90's Chevy Suburban. (Also mounts very nicely under a tour pac as well ) They're like 20 bucks at a salvage yard. On the fenders I placed those LED lites that are suppose to mount to the mirrors of a vehicle for signaling. At night I'd like the driver in the lane next to me on a freeway to see that I'm changing lanes. I also put on a chrome vinyl trim to simulate a chrome bumper and I started making fender skirts for the trailer and the trike. I think the trailer looks pretty cool so far.
Since the rear mags on the trike dont match the trailer's mags. The fender skirt tends to mask this; allowing the look of the two, to flow together.
zoood
I'm still progressing on the trailer's hatch. As I stated before. The hatch is of an RV application for venting in a horizontal wall.
So the modifications I had to do to this thing is a real challenge.
This view is of the underside of the hatch. I had just painted certain areas on it that would show when finished. The venting sections that you see in the center. I have fabricated an aluminum box that will fit tightly over this. I left the vented ribbing for strength since the hatch is made of plastic. I had also added two side push button latches. These set flush to the surface when latched in place. When they are pressed. The center pops out about 2 inches and has finger holds. These are what I will be pulling up on when I need to remove the hatch. I also installed a keyed lock in the center. The tabs on the back (not shown) were made of plastic. I removed them and replaced them with steel.
When I complete this hatch. I'll put up pictures.
While the hatch is drying. I started building the mirror finished SS spoiler that will set in front of the hatch. The spoiler's purpose is to aid in deflecting rain, up and over the opening when my black lab rides in the trailer.
Designing this spoiler to mount on a lid that has a downward curvature in every direction was another tough challenge. Especially with the new tools I purchased that I'm still learning to use. That old saying, "Practice makes perfect" is WRONG! Perfect practice makes perfect!
I made a back section and on it's bottom side I formed it to have a curvature that conforms to the lid's surface. I had placed low tact wide masking tape on the lids surface to make my measurements and to avoid scratches to the surface.
After forming the SS spoiler. I wanted to try and assemble it with as few signs of rivets or machine screws as possible. In the next picture the red arrows show where a rubber "U" channel was adhered. This allowed a press a fit of the spoiler and the backing mount. It can also be dismantled if necessary.
This picture shows that the center of the spoiler rests on the lid.
Where as both ends are elevated slightly. Depicting the curvature in the lid's surface. The stainless steel had an enough flex to allow for it's fixture to the surface. I used a 3M two sided tape, sandwiched between the spoiler and the fiberglass lid. I activated only one side of the tape to adhere to the bottom side of the spoilers lip.
After mounting the spoiler to the lid. I could now get tracings off the ends of the spoiler to fabricate it's sides. At this stage of my build. I'm presently making the ends to finish this project.
Below is a good look at how the spoiler will look.
zoood
Im just about finished with the trailer. I did hook it up to the trike to see how it looks. The ball hitch needs to be raised for the trailer to tow level. I had added 2" over stock tubes to the front end. This is what made it pitch downwards.
I also finished the spoiler.
And the removable hatch in the trailer's lid.
zoood
The Dog House Trailer is just about complete. Road test as soon as the weather breaks.
The hatch will soon have a stow-a-way place inside the trailer.
I rubber mounted 1/2" plywood to the floor. Carpeted it and attached a ring for the dog's chain.
Ready to Ride.
zoood
I am not sure if dog is looking happy in his trailer but as i know dogs they just love to be on the move with the wind in their fur
He's not happy. Looks like he realized that he was just in there for pictures and that the trailer isn't hooked up to the trike. Soon Ill hook it all up and let him get a snoot full of wind, that and his eyes too. Then I'll introduce him to Doggles.
My dog just loves being in the car on a journey he will sit calmly and look out of the window for a wee while then settle down and be really peaceful the rest of the time he is a raging menace but in the car calm
