J
Jack Klarich
Guest
Hopfully it uploaded
:sLooks normal to me
Thanks , so i recon i don't have any compression releases , is there other things that could effect the compression i tried leaving one plug in and the other half way in and grounded the one that was half way and it was able to turn as if it had a very weak battery , but whenever the air pressure released through the cycle the motor seemed to go speed up , don't know if that's relevant
Do you have a compression gauge? If not it would not hurt to go get one and see what kind of compression the motor is produceing.
Agree But he needs it to spin good to get an accurate reading first, that said if the compression is indeed the problem he will have choices to fix this A high torque starter, IE different head gaskets and base gaskets, lower compression pistons or compression releases,
My thoughts was he has one plug out and the gauge in the other may be it will show high comp value on the one and that would tell him if it is compression problem or mechaniceal problem wit hstarter jack shaft.
:s Good idea, and then do the other cylinder and compare
I dont know what the norm reading should be but if motor locks say at 100 psi then it is not due to high compression, it is other mechanical problem.
